DistributionList modes
Post by RvdH » 2021-09-10 19:45
Today a had to setup a distribution list for a client, and they asked if it was possible to allow anyone in their domain to send to the list (not being all members)
So i browsed through the code and noticed there are a few more distribution list modes listed in hMailServer.idl
typedef
[uuid(90745436-4C3F-11D9-AD17-A0BCEA20CD06),
	helpstring("Distribution list mode")]
	enum
	[helpstring("Anyone can send messages to this distribution list.")]
	eLMPublic = 0,
	[helpstring("Only members of the distribution list can send to the list.")]
	eLMMembership = 1,
	[helpstring("List is only for announcements.")]
	eLMAnnouncement = 2,
	[helpstring("Anyone in the domain can send to the list.")]
	eLMDomainMembers = 3,
	[helpstring("Anyone with an account on the server can send to the list.")]
	eLMServerMembers = 4,
} eDistributionListMode;
RecipientParser.cpp however doesn't contain those additional distribution list modes, the way i see it the mode listed as DomainMembers distribution list mode would fit this clients needs.
I think i fairly easy can add this DomainMembers mode
What do you guys think, can this be a valuable addition?
Other possibility would be to alter the Announcement distribution list mode to accept wildcard addresses *@domain.com
Re: DistributionList modes
Post by katip » 2021-09-10 21:16
with the option "Require SMTP Auth" checked, i think #4 is already covered, no?
#3 might be useful. kinda restricted #4. i'd use it.
HMS 5.7.0, MariaDB 10.4.10, SA 3.4.4, ClamAV 0.103.2
Post by RvdH » 2021-09-10 21:19
katip wrote:
2021-09-10 21:16
Yup, i mainly am interested in the DomainMembers
DomainMembers + Require SMTP Auth checked, behaves like only real accounts in the domain can send to the list (i think)
Post by mattg » 2021-09-11 01:50
Domain members would absolutely make this useful
Especially if members of the group were auto-populated, or we could use *@example.com (or perhaps 'all@example.com') to send to all addresses in that domain.
Post by RvdH » 2021-09-11 01:54
@mattg
Not entirely sure if you understand the mode, this is a extra Security Mode, eg: who's allowed to send to the list
https://github.com/hmailserver/hmailserver/pull/392 (also works for domain alias :wink: )
Post by mattg » 2021-09-11 02:14
Yes I get that
To be really useful, it ALSO would be good to have the recipients - members auto-populate with all accounts/ aliases from the domain.
Thinking a work situation
OHS@example.com for all employees to use to report Health and Safety issues>> Members only the OHS Officer(s) What you have found will work here
management@example.com for all employees (who know the address) to use to raise issues with management... >> members of the management team What you have found will work here
notices@example.com for all employees to use to say "owner of the mouldy cheese in the staff fridge - please remove it) to everyone in the entire company >>> THIS IS WHERE THE all@example.com would be useful
Post by RvdH » 2021-09-11 02:22
2021-09-11 02:14
Yes I get that
auto-populate, i don't want the sysadmin to end up without work, and you can do that by script :mrgreen:
Post by katip » 2021-09-11 06:12
not directly related with the topic, but while you set a hand on it...
deletion of an account should remove it also from all distro lists where it was a member.
we use many local distro lists and most users are members of multiple lists. albeit i do this by script (send a mail with subject "purge user@local.com" which triggers the function) this should be a natural result of an account deletion. or you have to know who is member of which list and do it by hand one by one.
Post by RvdH » 2021-09-11 10:52
katip wrote:
2021-09-11 06:12
viewforum.php?f=2 :lol:
Automatically purging is a complicated task i think, especially when users don't use their account names in distribution list but for example use a alias instead (we have a few client with domain permissions, it is really unbelievable the mess they make)
Post by katip » 2021-09-11 13:21
2021-09-11 10:52
yes i see... luckily i'm the only domain/server admin and put only account addresses in lists :lol:
in fact after an account deletion exclusive aliases (name.surname@...) should also be removed, but generic aliases (sales2@...) should stay (or better reset temporarily to admin/postmaster account??) , and yes it's complicated.
maybe, manually entering a new recipient could be restricted only to non-local addresses (anyone@external.tld), and any local recipient would have to be selected from drop list (real accounts) only. that would give some integrity.
Post by mattg » 2021-09-12 01:08
The problem is for domains that are partially hosted externally, some here - some there
