https://d-fault.nl/files/SpamAssassinFo ... 8.x%29.zipThis is a modified SpamAssassin for Windows package, which unlike the official JAM Software distribution
will not run without a installed version of Strawberry Perl 5.38.x x64 (any version in the 5.38 branch should work)
Included/Updated in this package:
- MaxMind::DB::Reader, version 1.000014
- Razor2::Client::Agent, version 2.86
- Mail::DKIM, version 1.20240124
- Mail::DMARC, version 1.20240314
- Mail::SPF, version 3.20240206
- Mail::SpamAssassin, version 4.0.1 Revision 1916544
- ClamAV Plugin (disabled)
- HashBL.cf with working example, see http://msbl.org/ebl.html
Changes:
Uses "C:\ProgramData" as default location for \.razor and \.spamassasin folders when spamd.exe is run as "Local System" user (eg: Default Service Account)
Enjoy!
SpamAssassin 4.0.1
SpamAssassin 4.0.1
"SpamAssassin for Windows" 4.0.1 Perl 5.38.x x64
Re: SpamAssassin 4.0.1
"SpamAssassin for Windows" 4.0.1 Perl 5.32.x x64
"SpamAssassin for Windows" 4.0.1 Perl 5.30.x x64
https://d-fault.nl/files/SpamAssassinFo ... 2.x%29.zipThis is a modified SpamAssassin for Windows package, which unlike the official JAM Software distribution
will not run without a installed version of Strawberry Perl 5.32.x x64 (any version in the 5.32 branch should work)
Changes:
Enjoy!
https://d-fault.nl/files/SpamAssassinFo ... 0.x%29.zipThis is a modified SpamAssassin for Windows package, which unlike the official JAM Software distribution
will not run without a installed version of Strawberry Perl 5.30.x x64 (any version in the 5.30 branch should work)
Changes:
Enjoy!
"SpamAssassin for Windows" 4.0.1 Perl 5.32.x x32
"SpamAssassin for Windows" 4.0.1 Perl 5.30.x x32
will not run without a installed version of Strawberry Perl 5.32.x x32 (any version in the 5.32 branch should work)
Changes:
Enjoy!
will not run without a installed version of Strawberry Perl 5.30.x x32 (any version in the 5.30 branch should work)
Changes:
Enjoy!
PS, if using Perl 5.38.x you need DBD::mysql as it is not installed by default, latest version requires MySQL 8.x, you can work around this by installing older version:RvdH wrote: ↑2024-04-06 01:39"SpamAssassin for Windows" 4.0.1 Perl 5.38.x x64
Changes:
Enjoy!
perl -MCPAN -e shell
install DVEEDEN/DBD-mysql-4.052.tar.gz
SpamAssassin 4.0.1 has native support for pyzor, so you do not need python
You enable this like so:
loadplugin Mail::SpamAssassin::Plugin::Pyzor
use_pyzor 1
pyzor_perl 1
Hello @RvdH
need assistance
I installed 4.0.1 with perl 5.38.x x64 as above everything works fine except sometimes i get this warnings in SA Logs, can you help resolve this (previously used your 4.0.0 SA and no problem at all)
does it require and specific perl module?
need assistance
Sat Oct 12 01:09:58 2024 [-6376] info: util: idn_to_ascii: conversion to ACE failed, string contains a disallowed character: 'www.wire\x{E2}\x{80}\x{93}india.com' (charset UTF-8) (LibIDN2)
Sat Oct 12 01:09:58 2024 [-6376] info: util: idn_to_ascii: conversion to ACE failed, string contains a disallowed character: 'www.tube\x{E2}\x{80}\x{93}india.com' (charset UTF-8) (LibIDN2)
Sat Oct 12 01:09:58 2024 [-6376] info: util: idn_to_ascii: conversion to ACE failed, string contains a disallowed character: 'www.metec\x{E2}\x{80}\x{93}india.com' (charset UTF-8) (LibIDN2)
Sat Oct 12 12:43:04 2024 [-12300] info: util: idn_to_ascii: conversion to ACE failed, string contains a disallowed character: '\x{E2}\x{80}\x{93}' (charset UTF-8) (LibIDN2)
I don't see any errors only log line(s) that inform that conversion failed due to unallowed characters
it only is a problem once you see that with every single mail not when it randomly pops up
And yes i see those line as well sometimes, i even did on 4.0.0 which used the same Net::LibIDN2, version 1.02 as 4.0.1
FYI, it is a optional module, feel free to delete it if those message annoy you
..\runtime\inc\lib\auto\Net\LibIDN2\LibIDN2.xs.dll
..\runtime\inc\lib\Net\LibIDN2.pm
Noted
by Error I meant conversion to ACE failed
Anyway Thanks
Anyway Thanks
It still scores fine as well, so it is not that these message abandon other checksFri Oct 11 12:02:49 2024 [-8688] info: spamd: connection from MyServer [127.0.0.1]:1035 to port 783, fd 6
Fri Oct 11 12:02:49 2024 [-8688] info: spamd: processing message <13041761812d0d8cea2784836.b205e58eee.20241011100221.27d9ad4c6c.83655b36@mail5.sea61.rsgsv.net> for (unknown):0
Fri Oct 11 12:02:49 2024 [-8688] info: util: idn_to_ascii: conversion to ACE failed, string contains a disallowed character: '\x{EF}\x{BF}\x{BC}' (charset UTF-8) (LibIDN2)
Fri Oct 11 12:02:49 2024 [-8688] info: util: idn_to_ascii: conversion to ACE failed, string contains a disallowed character: 'www.\x{C3}\x{AF}\x{C2}\x{BF}\x{C2}\x{BC}.com' (charset UTF-8) (LibIDN2)
Fri Oct 11 12:02:49 2024 [-8688] info: util: idn_to_ascii: conversion to ACE failed, string contains a disallowed character: '\x{C3}\x{AF}\x{C2}\x{BF}\x{C2}\x{BC}' (charset UTF-8) (LibIDN2)
Fri Oct 11 12:02:55 2024 [-8688] info: spamd: identified spam (4.8/4.0) for (unknown):0 in 5.8 seconds, 280292 bytes.
Fri Oct 11 12:02:55 2024 [-8688] info: spamd: result: Y 4 - BAYES_40,CUSTOM_MANY_EXTRA_BL,DKIM_SIGNED,DKIM_VALID,DKIM_VALID_AU,DMARC_PASS,HEADER_FROM_DIFFERENT_DOMAINS,HTML_MESSAGE,KAM_BODY_MARKETINGBL_PCCC,KAM_MARKETINGBL_PCCC,LOCAL_SCAM_15,LOCAL_URI_TRACKINGURI,MIME_QP_LONG_LINE,RCVD_IN_DNSWL_NONE,RCVD_IN_IADB_DK,RCVD_IN_IADB_ESP,RCVD_IN_IADB_LISTED,RCVD_IN_IADB_RDNS,RCVD_IN_IADB_SENDERID,RCVD_IN_IADB_SPF,RCVD_IN_JUSTSPAM,RCVD_IN_ZEROSPAM,SPF_HELO_PASS,SPF_PASS,TXREP,URIBL_GREY scantime=5.8,size=280292,user=(unknown),uid=0,required_score=4.0,rhost=MyServer,raddr=127.0.0.1,rport=1035,mid=<13041761812d0d8cea2784836.b205e58eee.20241011100221.27d9ad4c6c.83655b36@mail5.sea61.rsgsv.net>,bayes=0.232789,autolearn=no autolearn_force=no,shortcircuit=no
Mine didn't
Sat Oct 12 01:07:21 2024 [-6376] info: spamd: connection from MAILSRV.MYDOAMIN.COM [127.0.0.1]:53164 to port 783, fd 6
Sat Oct 12 01:07:21 2024 [-6376] info: util: idn_to_ascii: conversion to ACE failed, string contains a disallowed character: 'www.wire\x{E2}\x{80}\x{93}india.com' (charset UTF-8) (LibIDN2)
Sat Oct 12 01:07:21 2024 [-6376] info: util: idn_to_ascii: conversion to ACE failed, string contains a disallowed character: 'www.tube\x{E2}\x{80}\x{93}india.com' (charset UTF-8) (LibIDN2)
Sat Oct 12 01:07:21 2024 [-6376] info: util: idn_to_ascii: conversion to ACE failed, string contains a disallowed character: 'www.metec\x{E2}\x{80}\x{93}india.com' (charset UTF-8) (LibIDN2)
Sat Oct 12 01:07:22 2024 [9020] info: prefork: child states: IB
Sat Oct 12 01:07:24 2024 [-6376] info: spamd: Tell: Did nothing for (unknown):0 in 2.2 seconds, 23855 bytes
Sat Oct 12 01:07:24 2024 [-11600] info: spamd: connection from MAILSRV.MYDOMAIN.COM [127.0.0.1]:53169 to port 783, fd 6
Sat Oct 12 01:07:25 2024 [9020] info: prefork: child states: BI
Sat Oct 12 01:07:26 2024 [-11600] info: spamd: Tell: Did nothing for (unknown):0 in 2.3 seconds, 51377 bytes
Sat Oct 12 01:07:27 2024 [-6376] info: spamd: connection from MAILSRV.MYDOMAIN.COM [127.0.0.1]:53175 to port 783, fd 6
Sat Oct 12 01:07:27 2024 [9020] info: prefork: child states: IB
Sat Oct 12 01:07:29 2024 [-6376] info: spamd: Tell: Did nothing for (unknown):0 in 2.3 seconds, 53734 bytes
Sat Oct 12 01:09:57 2024 [-11600] info: spamd: Tell: Did nothing for (unknown):0 in 3.2 seconds, 200994 bytes
Sat Oct 12 01:09:58 2024 [-6376] info: spamd: connection from MAILSRV.MYDOMAIN.COM [127.0.0.1]:53534 to port 783, fd 6
Sat Oct 12 01:09:58 2024 [9020] info: prefork: child states: IB
Sat Oct 12 01:10:00 2024 [-6376] info: spamd: Tell: Did nothing for (unknown):0 in 2.2 seconds, 23828 bytes
Sat Oct 12 01:10:00 2024 [-11600] info: spamd: connection from MAILSRV.MYDOMAIN.COM [127.0.0.1]:53539 to port 783, fd 6
Sat Oct 12 01:10:01 2024 [9020] info: prefork: child states: BI
Sat Oct 12 01:10:02 2024 [-11600] info: spamd: Tell: Did nothing for (unknown):0 in 2.2 seconds, 5735 bytes
Sat Oct 12 01:10:03 2024 [-6376] info: spamd: connection from MAILSRV.MYDOMAIN.COM [127.0.0.1]:53545 to port 783, fd 6
\x{E2}\x{80}\x{93} = "-" eq: en dash
https://codepoints.net/U+2013
Not sure why LibIDN2 complains about a disallowed character
https://metacpan.org/pod/Net::LibIDN2
no mention of function call idn_to_ascii, this is something in SA Util.pm
Do we need to update util.pm from current sa repo from github?
You can try, but be warned the main branch on github is (pre)4.0.2 and it may not be backward compatible with 4.0.1
I would simply ignore them messages or if you are really annoyed disable the optional module like said before
